Make an offer on whats left, 25 parts under $250 each!
Livorsi throttle only w/trim in handle $150 Livorsi fiberglass side mount throttle pod, new $125 Recessed fuel vent 5/8" 90 deg. $20 High flow fuel filter head 1/2" threads $20 Livorsi trim tab switches w/mounting plate, new $50 Lovett 900 3/4" hose bilge pump $50 30 1/2" dock lines w/carabiners braided on $100 Bravo HP gimbal bellhousing $250 TB4 v8-22 module $50 TB4 v6-14 ign. module $125 TB5 v6 ign. module $50 Rule hand bilge pump 1 1/2" hose $20 Single engine mount plate 32 1/2" wide, new $125 1" std shaft solid hub $20 2] Sherwood crank driven BB water pump w/ 2 groove crank pulleys $150 pr. Eickert gen 4 BB remote oil adapter $20 Kiekhaefer spare prop holder, new $100 ]2 stainless 33c cable clips $10 pr. 33c stainless ball joint $10 Keith Eickert tailpipes $50 pr. 2] elec hatch actuators combine to make 1 complete $25 pr. Perko water inlet fitting $10 #10 AN thru hull $10 #10 AN bravo water inlet $10 4] 20 in. spring lift shocks w/brackets $25 all Khiekhaefer zero effort control parts $50 Livorsi 2" water pressure gauge, new $20 Gil 10 qt. 8" deep oil pump pickup, new $20 914-262-1898
