Go Back  Offshoreonly.com > Owners Forum > Donzi
Engine/chassis ground >
Old 04-20-2013 | 04:06 PM
Default Engine/chassis ground
Where can I find the engine/chassis ground on a 33zx. I think I found the ground block behind the battery switches. There is a black 2/0 awg wire on main lug and several green wires on the block. Under the helm is a dc ground block labeled such. Wiring up an inverter and need to ground inverter chassis.
donzi33zx is offline
Old 04-21-2013 | 08:24 AM
Scott B's Avatar
Look on the bellhousing for a stud with grounds attached to it.
Scott B is offline
Old 04-24-2013 | 07:32 PM
I found through research the manufacturer wanted ac side of inverter grounded to dc side so to trip breaker on dc input side.
