F 272 sr1 63mph wot 4500rpm 25p mirage props
yesterday I got 4500 rpm wot at 63 mph bravos 1.5 w/ 2 on board and 3/4 tank of fuel using my 25 mirage props,would labbing these props give me more speed? Is it worth it? I also have a spare set of Bravo 1 26p props that I have not tried .what should I expect with these last 2? Any opinion would be greatly appreciate it.
The 26's are too big. I'd try a set of 23's first. Then decide which ones to lab after discussing the results with Brett from blades. Iirc I had the boat up to 67? With 2 on board and 1/3-1/2 tank @5000 rpm
I've already tried mirage 23's and I was going over 5000 rpm more like 5200 and I thought it was too high already not seeing more than 63 either, I probably need to try 23's M plus
Anyways i think I can still take advantage of around 400 rpm more out of these big blocks with the right set up, so let's say I lab the 25p mirages,how many more rpm should I get?
Diego9040
Let us know any questions you might have.
Labbing the 3 blade props is the best route for speed on your hull. We may want to test some Plus series propellers too.
Brett
Brett
[email protected]
[email protected]
