OT: Truck Suspension
Old 07-24-2002 | 09:16 PM
BTJ88
Question OT: Truck Suspension
I am wanting to beef up the rear end of my 1/2 ton Chevy. As I see it - I basically have 3 options:
1. Adding leafs
2. Helper springs
3. Air bags
Does anybody have experience or advice on doing this sort of thing?
Old 07-24-2002 | 09:59 PM
BLOWN 1100's Avatar
BTJ88
Air bags are the only way to go. I used them on a
Z71 , when not hauling a load use small amount
of air for a nice ride then air them up when needed.
My 2 cents
BLOWN 1100 is offline
Old 07-24-2002 | 10:09 PM
Audiofn's Avatar
Charter Member #232
I have done airbags but they are expensive. They did kick major azz!!!
I also know a buddy used the helper leaf springs and he really likes them
Jon
Put your best foot forward!
Audiofn is offline
Old 07-24-2002 | 10:18 PM
liquid asset's Avatar
EITHER AIR BAGS OR BUY A 3/4 TON
liquid asset is offline
Old 07-24-2002 | 10:23 PM
Havasu Hangin's Avatar
Thumbs up 3. Air bags...
I air bagged my Tahoe...pretty much a weekend job. The bags wern't that tough, but the compressor and related plumbing/wiring took awhile.
Much better now...less sway...I think the steering geometry really likes the normal ride height...I like the fact that I can pump em up when I really load it down...right from the driver's seat...
www.summitracing.com saved me around $100 off the local shops...
Havasu Hangin is offline
Old 07-24-2002 | 10:35 PM
buck183's Avatar
BTJ88,
I get this question every week in my store.
There are pros and cons to each choice.
The Add-A-Leaf will be the cheapest option. Pretty much a quick fix IMO. An Add-A-Leaf is actually for lifting the vehicle more then anything. You will get a slightly rougher ride with this and your truck will ALWAYS sit higher in the rear.
The Helper Springs are quite a bit more expensive then the Add-A-Leafs. With the Helper Spring you will have the towability (word?) without having to look at a raked truck all the time. You can adjust them to fit your needs with ease. Probably more suited for a towing situation then an Add-A-Leaf IMO. You can adjust the height of your truck up or down in case you are not towing also.
Air Bags are probably the best option but can be expensive. Very easy to adjust for obvious reasons. If you go with an on board Air Compressor it will make things REALLY nice. You can save money and opt to air them up at the station or with a compressor. Probably rated about the same as a Helper Spring for heavy towing. If your a do it yourselfer you could get into the Air Bags for a reasonable price and install them yourself.
Ease of installation......Helper will be the easiest. I would say the Air Bags and Add-A-Leaf would be a tie IMO.
PM me if you want to ask me anymore questions. I can give you some pricing ideas if you want to compare to prices in your area.
Good luck
Buck
#183
buck183 is offline
Old 07-25-2002 | 09:37 AM
I justhad a leaf added to the rear of my Z71 1/2 ton. It did give it a slightly firmer ride but not bad at all. It made a HUGE difference when towing! The increased rake of the truck is negligable in my opinion. You can always adjust the front height of the truck by turning the tie rods I believe. A friend did it to his 2500HD so that it sat and rode level. I left mine alone. I don't know if this helps, but for the me the adding of one leaf to the rear was adequate.
Good luck.
Shane
Shane is offline
Old 07-25-2002 | 10:06 AM
Smitty's Avatar
All I have to say is AIRBAGS with an on-board compressor and dash mounted controls.
Nothing else even comes close!!!!!
Smitty is offline
Old 07-25-2002 | 10:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Airbags are the way to go. Send a PM to OutlawMark from this board. He can get them for you through the shop he manages. Outlaw Motorsports, owned by 'Skater" (Mark House) of this board also.
Sydwayz is offline
Old 07-25-2002 | 11:00 PM
buck183's Avatar
That's funny, didn't buck183 just make a post saying he could get them??????
Buck
#183
buck183 is offline
