questions about 500 EFI's >
Old 04-24-2013 | 07:14 PM
GDM
Default questions about 500 EFI's
I am looking at a boat for sale with 500 EFI's that have just under 300 hours.
what maintenance should I expect in the near future ?
how many hours can these engines go before they need to be rebuilt ?
any feedback on these engines will be greatly appreciated
thanks in advance
gary
GDM is offline
Old 04-24-2013 | 09:06 PM
Many will tell you at those hours the top ends should be freshened. Head gaskets upgraded to Mls vs the stock single layer which are prone to failure. Valve springs are also a hot topic, 250 hrs is the common interval on the stock springs. A broken spring will make a disaster out of your internals after the unsupported valve drops into the engine.
Other wise maintenance will be similar to any merc bbc engine.
4bus is offline
Old 04-24-2013 | 09:22 PM
Agree on the head gaskets, have seen way to many go bad 250-300 hours, good advice from 4bus on the springs.
abones is offline
Old 04-24-2013 | 09:28 PM
GDM
thanks for the feedback
so if I were to buy this boat Im guessing I should do "the top ends" right away
how much approx. does that cost ?
trying to figure out how much I want to offer on the boat
thanks in advance
GDM is offline
Old 04-24-2013 | 09:35 PM
if u get to them before some thing go's it will run u about 2 to 3k per motor. if u have to do a full rebuild on one if some thing go's its around 8k. im at 345 hours and i broke one so now it has all been adding up. if u have one out and the other top off its better to just do as much as u can because its all open. and it adds up fast, i was just looking to do top ends for 4k and now 4 months in im at 20k.
1989mach1 is offline
Old 04-24-2013 | 09:38 PM
read this one i started before getting my new boat covers what u r asking just faster lol
http://www.offshoreonly.com/forums/g...7-500efis.html
GDM
I was thinking as soon as I get the boat , before I even use it , I address this "top end"
so... I need to do valve springs and head gasket
anything else for maintenance ??? while Im at it ?
GDM is offline
Old 04-24-2013 | 09:41 PM
impellers, plugs,cap,belts and filters r always good to do too
Old 04-24-2013 | 09:44 PM
i would do the lifters to that is what broke on mine and coused the full rebuild with a new cam
[IMG][/IMG]
Old 04-24-2013 | 09:45 PM
GDM
thanks for the link
GDM is offline
