Anyone with first hand experience with viynal paint/dye
Just had my boat wrapped and I would like to get rid of the purple graphics on my boats interior. I was thinking about trying the dye/paint from SEM products. This is just something to get me by until next winter when I have the interior done.
Again looking for people's input who have used the paint/dye.
Also just realized I fat fingered vinyl in the title. Can someone fix that for me please.
I used vinyl paint on a set of bolsters I just sold. Came out very nice. Did lots of prep work to make sure they were clean and paint would stick well. The original colors were dark so it took alot of coats to cover them with white paint. Reviews I read online said most people were getting 2-3 years out of the paint.
clean it with grease/wax remover then a couple of lite coats of bulldog adhesive promoter then spray, it will last along time if done correct, just do lite coats instead of heavy , if the material is soft your good if its hard well then it will work but not as good. do not use ascetone it will melt the vynil if used wrong, ive done mine before and never had it get sticky, use good materials also.
Also, the adhesion promotor is a good idea, after a thorough cleaning with mild dish soap and warm water, using a scotchbrite pad as a sponge. The scotchbrite will scuff it enough to remove surface dirt, and make things stick well.
It's really not that kind of "dye" . Most assume its dye like food coloring or something. It's more or less a paint, that is elastic . When cured, it will chip/peel, not rub off like shoe polish.
I actually even did my steering wheel with it. 3 seasons and it still looks good. And lots of sweaty tight knuckle driving !
Crazy Energy
