Front Cylinders not Firing >
Old 04-26-2013 | 08:47 PM
Default Front Cylinders not Firing
Motor: 502 with 250 blower and duel Holley 850 carbs
Problem: when I start the motor it runs for about 20 seconds then the front cylinders cut out. I know this because the front headers are cold and the boost gauge needle is shaking back and forth at with little vacuum. If I let it sit 10 min. it starts fine then the same thing over and over. Two week a go it was doing the same thing and finally it started to idle correctly after about 6 starts!!
Things I've checked: compression check is good, CMI's don't leak.
Things I've swapped with other motor: front carb, ignition system (ignition module, distributor, sensor and coil) and fuel pump.
I've noticed a little moisture on one of the front spark plugs and checked the exhaust port at the header and there was about of a spoon full of water. I figured this was reversion from when the cylinders cut out.
What could it be?
Seahawk 2000 is offline
Old 04-26-2013 | 09:58 PM
it could be those cylinders have the valves adjusted to tight and when the oil pressure pumps the lifter up one of the valves is not seating properly.
mike tkach is offline
Old 04-26-2013 | 10:03 PM
what brand plug wires and how old are they,i have seen msd plug wires cause problems,and cyl 1 and 2 are the longest wires.
Old 04-26-2013 | 10:20 PM
vacuum gauge not steady I would agree with Mike possable valve train issue.
abones is offline
Old 04-26-2013 | 10:27 PM
Merc wires probably 7+ years old with NGK R5673-6 plugs.
Why would it idle good at the start and then go bad if it were the wires or plugs?
Old 04-26-2013 | 10:42 PM
Gauge is steady at the start then gets shakey when cylinders cut out.
Remember compression is good.
Old 04-27-2013 | 08:20 PM
What could it be?
Adjusted the valves today and no change. Removed CMI and all noticed small amount of water each header. Could there be a leak in the CMI that I can't detect when It's off the boat. it seems like the water is what makes it start idle bad after 20 seconds. Where is the water coming from?
Old 04-27-2013 | 08:41 PM
Try running it with the exhaust water supply disconnected and dumping into the bilge. Process of elimination would be my path to glory...good luck
MEANGREEN231 is offline
Old 04-28-2013 | 04:17 PM
ttt
Old 04-28-2013 | 10:33 PM
Vacuum leak? Try forcing choke closed on front carb and see if the fronts start firing again?
zz28zz is offline
