How many volts are supposed to be at ignition coil? >
Old 04-26-2013 | 10:20 PM
Default How many volts are supposed to be at ignition coil?
Hi, I have a 94 4.3lx with the thunderbolt ignition. How many volts are supposed to be at the coil? I think it is supposed to be 12v correct? I know older engines with points need to be lower with about 9v but I dont think that applies to electronic ignition. Am I correct? Thanks.
jbizub5192 is offline
Old 04-26-2013 | 10:25 PM
Yes 12 volts.
Griff is offline
Old 04-27-2013 | 08:03 AM
Audiofn's Avatar
Charter Member #232
I thought that some of the TB's were under 12 volts? My Formula it is lower I beleive. I do know that there is a wire that runs from the starter to the coil for when you are cranking to "boost" the voltage.
Put your best foot forward!
Audiofn is offline
Old 04-27-2013 | 05:10 PM
I'm going off memory, so I could be mistaken, but pretty sure the purple/key on wire at the coil should have 12 volts.
Griff is offline
Old 04-27-2013 | 05:24 PM
Wobble's Avatar
SORE MEMBER
i was thinking at least 45,000, assuming you have a competition coil
Wobble is offline
Old 04-27-2013 | 06:27 PM
phughes69's Avatar
All modern ignition systems (ones without points) should have 12 volts at the coil + terminal Point type ignitions systems will have 12 volts at the + terminal of the coil ONLY when cranking and maybe 9 volts at the + terminal when the engine is running.
phughes69 is offline
Old 04-27-2013 | 10:58 PM
Default fixx
12.6 + with just the ignirion on and 13.8~ 14.2 running..
FIXX is offline
Old 04-28-2013 | 03:38 PM
http://www.boatfix.com/merc/Bullet/83/83_24.pdf
96scarab is offline
Old 04-29-2013 | 09:25 PM
Thanks everyone for confirming the 12 volts!
Old 07-13-2016 | 10:52 AM
Bump:
Having issues with my boat not restarting after running great. It turns over but wont fire. Noticed 11.3V at the + side of the ignition coil, is this why it wont fire?
AWOL is offline
