Help! which way do the oil lines run? >
Old 04-26-2013 | 10:43 PM
LarryL's Avatar
Default Help! which way do the oil lines run?
Ok this might sound stupid, but i will ask anyway.
Which way should the oil run using a remote oil filter and oil cooler?
Should it run from the block though the oil filter, and then though the cooler, and then back into the block?
or............. block to cooler, to oil filter, back to block?
I think it is the first way but I want to be sure.
Thoughts?
Larry
LarryL is offline
Old 04-26-2013 | 11:00 PM
c_deezy's Avatar
Block to filter to cooler to block.
c_deezy is offline
Old 04-26-2013 | 11:06 PM
Best to filter the oil while its hot...more trash is filtered out that way.
sprink58 is offline
Old 04-27-2013 | 09:59 AM
This is Teague's. I forgot how I ran mine. I was also told to run the oil flow against water flow on the oil cooler.
whoya is offline
Old 04-28-2013 | 10:22 PM
LarryL's Avatar
Guy's thanks! Interesting that Teague's digram is reverse of what others are saying. (and I am going to go the the oil filter first, and then to the cooler)I agree that running the oil flow against the water flow gets the best cooling out of the oil cooler.
Everybody thanks for the help
LarryL is offline
