How do I get the top off this Holley carb?
Eng running very rich and doesn't want to idle.
Discovered eng would still run with both idle mixture screws closed so I need to open it up and inspect/cln. Can't figure out how to get the top off. It's loose on both ends, but seems to be held together in the middle near the choke plate area. Surely I don't have to drill some plugs out..
If someone could identify what model it is, that would be helpful too..
Thx for any help!
Thx for any help!
Well after doing a few quick searches on this carb, the only thing that I found so far is that its a MODEL 4010 and cfm is 760. But that came off of a guys web site so the info is as good as it is, I personally can verify the info but it sounds good, hope this helps a little.
Thx for help with identifying the carb.
I was able to confirm it is a 4010 model. Re-build kits are not to be found locally. Will take a few days to get one.
Is there a way to confirm if a power valve is bad or not with it removed from carb?
After the kiddo goes to bed, I'll go back out to the shop and remove the center stud
not to be a downer but I have had several of these model carbs and tossed them all. they were not very good which is why Holley stopped making them. if it is clean inside and rebuildable I would use it but if you find any issues with it like corrosion, etc. get rid of it and buy a 4150 model.
