repower Cary 50 diesel >
Old 05-02-2013 | 12:05 AM
Default repower Cary 50 diesel
I have a 50 Cary with man diesels it looks like the engines are sold.Thinking of replacing them with detroit 6v92 ddeck 625 hp with 2 to1 gears shaft and rutter does anyone know what kind of speed I will get
Herman1960 is offline
Old 05-02-2013 | 02:45 PM
Herman, need more information. How many engines? 2 or 4. Many of these had 4 gas engines. What size props? Diameter and pitch. I assume it is inboard and not surface drives since you state shaft and rudder. DDEC 6-92 are heavy engines probably 2300 lbs or so. The DDEC is only good for 2400 rpms so do the math.
Wannabe
wannabe is offline
Old 05-02-2013 | 02:59 PM
Fenderjack's Avatar
Pirate of the Chesapeake
But at 2300 lbs there still lighter than them Manns.Although he is installing less hp.The weight to power ratio will be better.Still not going to be a rocket.But nothing with straight inboard are usually.Just my 2 cents.Besides I want to buy that Cary LOL. JOHN SR
Fenderjack is offline
Old 05-02-2013 | 06:01 PM
Cool
Two engines the numbers on the wheel 48X28 they check about 28" dia. It would be nice if it would run 35 mph or is that pushing it.
Old 05-03-2013 | 11:39 AM
buy the one At national liquadators with the 4 yanmars the price is less than the driveline... and its done
delsol is offline
Old 05-03-2013 | 03:31 PM
Fenderjack's Avatar
Have you ever tried to buy anything from them it's almost impossible they all lie. JOHN SR
Old 05-03-2013 | 04:07 PM
i bought my boat there had no issues
pstorti is offline
Old 05-03-2013 | 04:16 PM
If you look at some Magnum 53's that had inboards and 8-92's at 700hp+ and they barely go 35 mph. The older fast 53's with Arensons ran 12-92's, big power around 900-1,000 hp to go 50 mph+.
I don't know how much smaller the Cary is but I think compared to the Magnum it is a much smaller boat than just being 3' shorter, maybe narrower, lighter, less deadrise????
HabanaJoe is offline
Old 05-03-2013 | 06:29 PM
Repowering with Detroit V-anything is leaping backwards into a ditch!
fossil fuel is offline
Old 05-03-2013 | 09:16 PM
i hear you about nat liq, ran me in circles on a 35 cig, but the cary's been there for a bit--- no other bidders -- no drama
4 bbc 415's= 50 mph
i would think that 4 yanmar 440's with arnesons should b close to that
delsol is offline
