HP500 Cylinder Head Bolt Torque Spec >
Old 05-03-2013 | 08:42 PM
Default HP500 Cylinder Head Bolt Torque Spec
What are they? 75? 80? 90?
Seahawk 2000 is offline
Old 05-03-2013 | 08:48 PM
abones is offline
Old 05-03-2013 | 08:53 PM
Default fixx
iron head step 1-4 20,40,60 final 80 then go over them again and again until their all the same..
alunimum head short bolts 65 and the med and long 75..
FIXX is offline
Old 05-03-2013 | 08:57 PM
Do they need to be retoqued again after first warm up?
Old 05-03-2013 | 10:03 PM
Registered User
I torque them to 75Ft.Lbs with oil under the head of the bolt. I do not re torque them after they leave my shop.
IRWIN is offline
Old 05-04-2013 | 02:24 AM
Default fixx
you know chris nelsen?
FIXX is offline
Old 05-04-2013 | 05:19 PM
Registered User
Yes I worked for kris Nelson for a few years before starting my own shop Fast Forward Race Engines.
IRWIN is offline
Old 05-05-2013 | 01:28 AM
Thats is what I have done also with the stock heads and head bolts using 30wt oil.
If you are using ARP bolts and/or their thread sealant lube, then the torque specs need to be adjusted to the mfg specs.
Griff is offline
