Engine mount ??? >
Engine mount ???
Engine mount ???
Old 05-04-2013 | 08:25 PM
Default Engine mount ???
'78 24 Pantera with a BBC, The engine mounts consist of a pedastal style mount on the factory mounting location on the side of the block. These pedastals sit on an angle bracket bolted thru the stringer. There are no other mounts or support back near the trans., is this normal? I was pissed I had to pull the engine out today so I didn't take pics but can tomorrow.
Nmbr1GMfan is offline
Old 05-04-2013 | 08:57 PM
vintage chromoly's Avatar
That is "normal". The rear attaches to the inner transom plate.
I'm going to fabricate a "cradle" to fit between the stringers for my front mount.
vintage chromoly is offline
Old 05-04-2013 | 10:01 PM
Everything seems solid but its quite a big span between the engine mounts and the transom plate.
Old 05-05-2013 | 08:26 PM
majority of the weight is on the stringers the tailstock just kinda sits there
sparky24 is offline
Old 05-05-2013 | 10:19 PM
Thanks guys. A slight knocking was why it came out and this is the culprit.
Old 05-07-2013 | 05:13 PM
owww looks like my old pistons
sparky24 is offline
Old 05-08-2013 | 04:11 PM
Yea Id say not too good. But on the flip side... Newer, bigger, better.
