What Livorsi Gauge sending units and hoses to use?
Im putting in a new set of Livorsi gauges in my 89 Baja. Also adding Elec. Fuel pressure and Elec. oil Temp and (mech)water pressure plus the regular ones. I hope the rest of the gauges work with my sending units. Wondering what ohm range sending units I need for Fuel Press. and Oil temp. Was thinking about getting them at Summit racing. For Mechanical oil pressure and water pressure gauges does size of line make a difference running to dash?
I tried Livorsi a bunch of times no answer and left messages (last Monday) and no return call. Looks like there customer service sucks.
I don't think livorsi uses anything special as far as sending units because they come stock on many boats & the sending units merc uses are gm. As far as the water pressure the plastic line that comes with the gauges likes to kink so be careful when running the line. Randy
Guess I will just order some of summit racing senders then. I just didn't want the gauges to be reading slightly off due to some special Livorsi ohm range.
