Prop hubs
I have a question about hubs... I recently sold a boat that had Bravo 1 props with 1 1/4 inch shafts with removable hubs. The number on the hubs was 840389K06. I kept one set of props with the hubs. The boat we purchased has Bravo X drives with 1 inch shafts. What would be the part number for the hub with 1 inch shaft with 400+ hp? The number I found is 835258K2. Thanks for any help.
835258K2 is the correct hubs if the Bravo 1 propellers are labeled Mercury Marine Bravo 1.
If the castings are labeled Mercruiser Bravo 1, you will need 835258K1.
Brett
Brett
[email protected]
[email protected]
