Go Back  Offshoreonly.com > Owners Forum > Awesome
Any pics of transom bracket on 3100 with triple outboards? >
Old 05-06-2013 | 12:26 AM
Default Any pics of transom bracket on 3100 with triple outboards?
If you have pics please send to [email protected]
blackbird345 is offline
Old 05-06-2013 | 06:13 PM
I know Jeff from Quebec has triples but not sure on bracket? My buddy has a Chris cat with quads on a solid bracket and I don't care for its looks. But I'm sure if it went one piece by stainless marine it would be sweet and then you could still have a boarding ladder? Me,I went with separate 12" jack plates and a swim platform in center. But my hull is a lot lighter than all other awsomes or Chris cats,A/o's.
feline frenzy is offline
Old 05-07-2013 | 12:22 AM
I went with a separate center bracket. I use a sport ladder on side of port bracket. Not sure how high to mount the bracket though. Guess ill have to wait for my friend to come by and measure it up properly. How fast does his go with 4 engines? What size engines?
How did you get yours so much lighter?
Old 05-07-2013 | 07:39 PM
He is still working out bugs with the 4engines, Jeff from Quebec can tell you about mounting the third bracket.look for him in a few threads in the awesome forum,very nice guy. And as for mine I bought the last shell I believe they made and it was in 2peices.so I got to set mine up for the outboards and change the balance point and do the bulk heads,everything non factory on mine is epoxy,carbon and Kevlar. Than about 3or 4 large garbage cans of multiple layers of gel coat ground off and faired! Hull blue printed. And the newer models were made a lot lighter than the older models. What year is yours?
Old 05-08-2013 | 08:58 PM
Mine is a '98. It came from the factory with twin outboards mounted on stainless marine brackets. We've got the new holes drilled now so hopefully tomorrow we can mount the bracket.
Old 05-09-2013 | 07:59 AM
How about some pix? And nice to meet another egg beater awesome owner as we're a small breed. Where ya from?
Old 05-31-2013 | 04:58 PM
How do I upload pics? Third engine is finally installed...any suggestions on the props? I was using three 24p choppers...but the acceleration makes the boat feel like a waverunner Anyone try Cleavers on these boats? Thought we'd need a prop with lift but someone recommended them so figured I'd ask...
Old 06-01-2013 | 08:26 AM
Default Props x3
Running 3 motors
3 blades on the 2 outside "26"
4 blade on the center "28"
Motors turning out
Center motor should be about 5" higher then outside.
18" set back on each
Hope this helps,
Note: alot more working running 3 motors
STV92 is offline
Old 06-03-2013 | 11:26 PM
Originally Posted by STV92
Running 3 motors
Motors turning out
Hope this helps,
That's great info thanks! How do I post pics?
