Advice 500 EFI valve parts >
Old 05-06-2013 | 09:43 AM
Default Advice 500 EFI valve parts
Need advice, Going to do valve job myself on 500 EFIs but dont know what parts i need or should replace and looking for stronger parts. What have others done when you did yours. Is it worth going with larger valves for more hp. How big can you go before the intake becomes the limiting factor.
Mark
formulafreak is offline
Old 05-06-2013 | 10:08 AM
Mark
If these are stock GM heads, I would use the Isky 8205 PLUS valve springs and matching retainers. These use the tool room outer springs that will hold up much better than standard spring material over the long haul. Bob Madera at Marine Kinetics can offer you a very good deal on these. He would also probably be a good person to talk to regarding replacement roller rocker arms, and possibly lifters. I assume you are planning to stick with the existing 500EFI cam.
Bob's direct number is 585-654-8583.
Budman II is offline
Old 05-06-2013 | 01:43 PM
Formulafreak: Check the Technical section, theres lots of information there. Budman has given you an EXCELLENT contact in Bob.
Wannabe
wannabe is offline
Old 05-06-2013 | 07:23 PM
Call Eddie Young he keeps this stuff on hand. (615-216-7449)
45SS is offline
