new help intake and carb setup >
Old 05-07-2013 | 05:27 PM
Thebossbultsma's Avatar
Default need help intake and carb setup
1988, MIE/340 (7.4) 454 4 bolt main Big Block
Dip it and hone the decks and cylinders cut .060 over
Block was detailed with all casting debris removed
Scat 9000 Crank 4.25, 496 stroker
manely - 6.385 in. Connecting Rods
comp cam 11-445-8 - Hydraulic Roller Camshafts,
Probe 496 Dome Top +18.0cc -
dart Cylinder Head, Cast Iron, 121cc Chamber, 308cc
New Harmonic Balancer
Rotating Assembly Fully Balanced
Comp Cams High-Tech pushrods #7954
118cc / 3angle valve
APR head bolt sets
ARP 1.90 rocker studs
crane gold 1.7 roller rockers
cam is set up for 1600-5400 rpms
I need to know what intake and carb would be best for this set up
Thebossbultsma is offline
Old 05-07-2013 | 06:53 PM
Help
Old 05-07-2013 | 08:41 PM
I have built several 496 strokers.
Used Edelbrock Air Gap and Holley 750DP.
1BIGJIM is offline
Old 05-07-2013 | 08:47 PM
Rookie's Avatar
I have a Weiand Stealth that that I have been running on my 600HP 454's that has been welded up and ported that I am going to be selling. It makes good power.
Let me know if your interested. I see your local
An Air Gap would also be a decent choice.
Rookie is offline
Old 05-08-2013 | 01:23 AM
I would use either an HP500 Dart Intake or an Air Gap Intake and an HP500(800cfm Holley #9022) carb.
Griff is offline
Old 05-08-2013 | 02:43 AM
I ran a performer rpm and a dart on my mild 454 a couple years back and lost 1 mph with the dart. I would go with the rpm air gap personally if I was to do it again. For the rpm of your cam I believe a single plan would not benifit you. I was seeing 5800 with my combo back then. Just my opinion though. As for carb, I like the Holley 850 Dp (marine). I ran a 750 Dp on mine (with less cylinder. head).....and it was sweet!
mustangmark is offline
Old 05-08-2013 | 05:59 AM
Air gap intake. The best carb setup for a 496 in that rpm range is a Holley with a 750 main body and an 850 base plate. I had mine custom made/cnc'd for $900 is was absolutely perfect on my 496...
Black Baja is offline
Old 05-09-2013 | 07:25 AM
Single plane or dual plane for this set up with an 850 cfm carb and air gap intAke
Old 05-09-2013 | 07:48 AM
I am finishing a warmed up 502 now and I used the rpm air gap. I have saved some dyno sheets comparig the air gap to the victor jr. from the web but a good 454 saw 20hp more at 3,400 rpm..... 30 HP at 3,900rpm and 20 lt/lbs better which was the largest gain and after 4,000 rpm the gains dismiss but the Air gap does better than the single plane all the way to 5,400 rpm and then the single plane is stronger by 10 HP and tq at 5,700................ This was using a typical camshaft of a nice, performance marine engine would use.
I would say the 496 would like the air gap and make more torque where you need it and make getting up on the plane easier.
I forgot to mention that the dyno test usEd a 1" open spacer...... TBF
tpabayflyer is offline
Old 05-09-2013 | 07:50 AM
Ok cool thanks alot
