Edelbrock Performer RPM Intake Manifold vs GM 6269318 marine intake >
Old 05-10-2013 | 09:00 PM
Default Edelbrock Performer RPM Intake Manifold vs GM 6269318 marine intake
what is the difference between these intakes
I bot 2 420 hp engines, all internals are the same between the 2
1 block is a gen 5 and the other is a mark 4
seeing that i am looking for them to match performance wise
are both of these intakes the same? or do I need to find another performer or vise versa? what is the difference between them
i am using the 420 hp crane cams
welfare racing is offline
Old 05-10-2013 | 10:49 PM
The air gap has the center divider notched out which will help a little on the top end. What you could do is notch the GM to match the air gap closer. I seen test where they notch a edelbrock performer intake which is pretty much like the GM and on the dyno it pretty much matched the performance of the air gap.
Attached Thumbnails Edelbrock Performer RPM Intake Manifold vs GM 6269318 marine intake-gm.jpg   Edelbrock Performer RPM Intake Manifold vs GM 6269318 marine intake-ag.jpg
picklenjim is offline
Old 05-10-2013 | 11:27 PM
I have an Edelbrock RPM Performer (used) that'll I'll sell for $100 + shipping. I can send pix if you're interested.
242LS is offline
Old 05-11-2013 | 08:55 AM
Not going to be the same performance wise..also the factory intake has bronze lined water passages to keep from eating out...I have a factory bronze lined one if you want to go that route...
ezstriper is offline
Old 05-11-2013 | 05:33 PM
i have one of the 6269318 OEM manifolds if you need one.
gsxr1216 is offline
Old 05-11-2013 | 09:02 PM
bck's Avatar
bck
Charter Member#568
I have a pair of the GM's with the divider cut down if you need them.
Straight bottoms and flat decks
bck is offline
Old 05-11-2013 | 10:25 PM
I am understanding that the performer Rpm (as the other emgine has the performer RPM intake) intake will give me more power then the GM one if this is true then the Performer is for me...any thaughts?
Old 05-12-2013 | 08:43 AM
You won't see any power difference off the dyno. Get whichever you can for the cheapest and cut the center divider down 1"
Unlimited jd is offline
