What kind of inserts are in the 6" dry tails??? >
Old 05-11-2013 | 08:42 PM
Default What kind of inserts are in the 6" dry tails???
Stelling headers with the 6" dry tails. When you look up inside it looks like a gattling gun with a bunch of round tubes. Who made it and can I pull it out??
302Sport is offline
Old 05-14-2013 | 07:17 PM
WildThing47's Avatar
They're welded in your Stellings, you could pull them out but they're integrated into the tail, you'd more than likely risk damaging the tail removing them. Keep em or run new pipes...Besides, they aren't all that quiet...
IMCO I believe makes the same style so does Borla...
Yours are 6" because the pipe has to be jacketed due to the fact it is dry, hence the extreme diameter...
WildThing47 is offline
