XINTEX Gas Sensor
Old 05-12-2013 | 02:51 PM
Default XINTEX Gas Sensor
Got my boat out of storage and after connecting the batteries, the gas fume detector in the bilge keeps sounding. I checked everything out and there is no gas leak and the alarm sounds even when the hatch is fully open.
I may have sprayed the sensor and got it wet with Simple Green while I was cleaning up after winterizing last fall.
Could this have fouled the sensor?
08 fastech 292 is offline
Old 05-12-2013 | 05:44 PM
Default fixx
yes,,unhook the sensor and see if the buzzard goes off or try smacking the sensor,,could have crud in it..
FIXX is offline
Old 05-12-2013 | 08:09 PM
Wobble's Avatar
SORE MEMBER
blow it off with air, however best bet may be to buy new.
mine kept going off, turned out I had a exhaust header gasket starting to leak.
the gas detector picked it up before I could even hear it.
Wobble is offline
