Lots of Parts (crossovers, IMCO Power Flows, 850 Holley carbs, cams, Brodix intakes >
Old 05-13-2013 | 12:34 PM
Default Lots of Parts (crossovers, IMCO Power Flows, 850 Holley carbs, cams, Brodix intakes
-2 Holley 850 carbs (one year of use) $300 a piece
-two crossovers (circulator bypass)
-Two sets of IMCO Power Flow exhaust with risers $650 a set
-Brodix IPBA intakes for DEMON set up
-Two cams (ill get specs on here soon)
-PORTED/polished 088 GM perf heads complete $1000
-8 quart new in box oil pan $250
-new alternator $100
-IMCO bravo end caps (for hyd steering) side by side (AEC-1 new$223.25 AEC-2 new$223.25) $125 a piece
- twin controls (shift /throttle) - correction does have trim control on thottle
-two steering wheels (one needs cleaning with keyed collar)
- cable steering set up for up to a 35' boat
-509 motor (built) (550 HP with dyno sheets) $4600
-gen V counter balancer
-gen V timing gears and chain
-two circulator pumps
-aluminum vavle covers (two sets)
-low profile valve covers (two sets)
-two crank driven sea pump set ups
-two number four drive flex plates
ALL parts off HP500 set up. Make me offers.
518-209-2528
overdooinit is offline
Old 05-13-2013 | 01:09 PM
Registered User
Hi there can you send me some pictures of the twin throttle shifter assembly and the hydraulic steering that you have I am interested let me know my email is [email protected]
Thunder cat is offline
Old 05-13-2013 | 08:45 PM
Also interested in throttles, what style, twin lever or separate throttle and gear?
Mario L.
Mario L. is offline
Old 05-13-2013 | 09:16 PM
Formula311-SR1's Avatar
Please send pics of Brodix intakes to [email protected]
Formula311-SR1 is offline
Old 05-13-2013 | 10:47 PM
Send me pics of carbs and throttle to [email protected]
pantera232 is offline
Old 05-13-2013 | 11:21 PM
pics of steering wheels, and valve covers to [email protected] thanks appreciate it. I also sent you a text. thanks again.
chaparral2300 is offline
Old 05-14-2013 | 12:21 AM
If the exhaust sets will fit a 502 mag bravo, I'm definitely interested. shoot me a pm if you still ahve them
txtraveller2002 is offline
Old 05-14-2013 | 01:26 AM
Pic of crossovers please [email protected]
jmoore1225 is offline
Old 05-14-2013 | 11:39 AM
I'll get pics out tonight
Old 05-14-2013 | 08:35 PM
Pics of steering wheels to [email protected] please. Thanks
FireLee83 is offline
