BBC starter bolts
Old 05-14-2013 | 11:03 AM
Default BBC starter bolts
are starter bolts anything special or can grade 5 or 8 hardware bolts be used? For a 454.
tnc110 is offline
Old 05-14-2013 | 12:11 PM
Bolts are special if using stock type starters
Aftermarket tilton ect use grade (8)
smokin' gun is offline
Old 05-14-2013 | 12:59 PM
Are You bolting to a bell housing or the block?
Flyin-Bryan is offline
Old 05-14-2013 | 01:46 PM
Talking
I'm assuming a 97 donzi. Don't have a trans
Get out of this thread trouble maker.
Old 05-14-2013 | 02:31 PM
Mbam's Avatar
Offshoreonly Advertiser
The bolts have an area that is knurled where the starter meets the block. The block is counterbored so this area fits tight. Takes the load off the threads and keeps the starter where it belongs. I learned the hard way back in the 60's!
So - answer is use the correct starter bolts.
Mbam is offline
Old 05-14-2013 | 02:44 PM
Get them at Autozone or O'Reillys in the help section they usually have them in stock
Slow Poke is offline
Old 05-14-2013 | 07:44 PM
Merc says they are 3/8-16 x 4.33 Called napa and the closest size they have are 4 5/8....are the 4 5/8 going to be too long?
tnc110 is offline
Old 05-15-2013 | 05:37 AM
you can stack washers under the heads to correct length, but get the right bolts...
dereknkathy is offline
Old 05-15-2013 | 09:26 AM
Get the right bolts, I almost wasted my flywheel with the wrong bolts.
ThisIsLivin is offline
Old 05-15-2013 | 02:52 PM
http://www.oreillyauto.com/site/c/de...=starter+bolts
