Is this the reason for low speed and 24% + slip??? photos of prop >
Old 05-15-2013 | 06:34 PM
Default Is this the reason for low speed and 24% + slip??? photos of prop
Vessel: Baja 265 DVX, 502 mpi engine. Bravo 1, 1.5 drive., 3 people, 18-20 gallons of fuel
Well I was able to get out on the water yesterday. I only ran 53 mph(gps) at 4800-4900 rpms. Prop is a mirage plus 23 that is pretty beat up. But will it cause the 24% slip I was seeing?
I then swapped props quick. Michigan Wheel SS prop, 25 pitch X 14.5 RH is all it says. It is perfect condition and came with the boat when I bought it. It ran 50 mph at 4800 or so rpms. 34%!!!!! slip. I see why the guy never used it, must be just junk design.
Also the boat feels "heavy" or "slugish" once trimmed out. Almost like a anchor is being drug.. Maybe the DVX is a slow hull???
Here is the mirage prop pics. Should I just find a new one that isnt damaged and start all over? Share your thoughts.
Rob
Photos of Michigan wheel prop.
92nsx is offline
Old 05-15-2013 | 06:39 PM
Id try a bravo1 22pitch
bobsbillets is offline
Old 05-15-2013 | 06:44 PM
4 blade. Wouldn't that have a even lower top end?
Boat cruises pretty well at 3000-3200 rpms, and 38 mph. (I dont remember the exact rpm's)
92nsx is offline
Old 05-15-2013 | 07:41 PM
I don't like Michigan Wheel props at all. Any that I've tested have always been terrible, worse than a merc aluminum prop. Your boat should like a Mirage but yours is pretty beat up. It's possible that the Skeg Guard is causing some cavitation. How bad is the skeg? I'd start by having your Mirage repaired which should be under $150 then look at removing that Skeg Guard.
endeavour32 is offline
Old 05-15-2013 | 07:46 PM
Under the steg guard I have no idea. It's been on there since I bought the boat. I'm almost afraid to look and see. LOL!
92nsx is offline
Old 05-15-2013 | 07:54 PM
Go into the general tech question area and post a skeg guard question, you'll get more action there. I think those little bolts and the gap between the guard and the drive would cause air to be pulled into the prop. I'm no expert but I know that area needs to be clean and smooth and with that guard on there it's neither. On my last boat about 1/3 of the skeg was cut off and I noticed not issues at all.
Old 05-15-2013 | 09:05 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
There are many issues.
Call us and we can answer some of those issues.
Brett
Our test program is a starting point.
[email protected]
bbladesprops is offline
Old 05-15-2013 | 11:56 PM
That beat to chit Mirage prop could easily cause high slip and poor performance.
It could even cause the bearings in your drive to go out prematurely.
Griff is offline
Old 05-16-2013 | 04:11 AM
That 25 p looks like it has some grooves cut into the front.. Hope you don't have drive issues, may just be prop is toast..
silent lucidity is offline
Old 05-16-2013 | 07:27 AM
I saw the groves on the 25 also when I first bought the boat. I tryed to figure out where they came from because once installed it doesn't rub on the drive at all! Only thing I can come up with is at some point it was installed with out the spacer. There is a brass spacer so it adapts to the bravo.
Brett, thank you for chiming in I will give you a call one of these days. Im guessing you guys probable know what a DVX likes in a prop. I just know Baja's in general needs bow lift in the prop.
Thank you all
92nsx is offline
