spark plug heat range selection >
Old 05-18-2013 | 07:21 PM
Default spark plug heat range selection
What is the good heat range spark plug for marine blower engine on 91 octane 120-140 engine temp.
Thanks for help.
supermx96 is offline
Old 05-18-2013 | 08:14 PM
Ac plugs mr41t
FIXX is offline
Old 05-18-2013 | 08:18 PM
rgrgoog's Avatar
Originally Posted by FIXX
Ac plugs mr41t
That is what I am going to run in my Supercharged engines as well. I have a 142 Thermostat in mine so the engine temps should be comparable as well.
rgrgoog is offline
Old 05-19-2013 | 01:57 AM
Thanks for help.
Give me a little more info on the engine. What is the compression, boost, what heads, etc.
Eddie
Young Performance is offline
Old 05-19-2013 | 09:51 AM
I'm running a 572 Merlin, Edlebrock Aluminum Heads, 6 lbs boost, 871 blower, dual 850 Holleys, 8.5 compression, Lighting Headers, MSD. Curently using NGK R5672A-8, are these the right plugs? Thanks
boatguy94 is offline
Old 05-19-2013 | 08:29 PM
Eddie
The engine is 454 gen 6 .060'' overbore,B&M 250 blower, Edelbrock Performer rpm aluminum ported head, hyd roller camshaft, comp ratio is 8:1, JE flat top piston, .039'' thick head gasket .008'' deck height, twin QFT 850 carb with pv boost ref, boost for now is 5lb but i would like to go at 7-8lb of boost, timing is set at 32 deg full in at 4000 rpm for now, I will control the timing with a map sensor probaly next week, I would like to see 34-35 in cruise no boost and 30-31 at 7-8 lb boost.
Thanks for your help
Old 05-21-2013 | 11:05 AM
I will try ngk # 8 heat range non projected plug and will see if it look too hot or too cold...
Old 05-21-2013 | 12:36 PM
The engine is 454 gen 6 .060'' overbore,B&M 250 blower, Edelbrock Performer rpm alumium ported head, hyd roller camshaft, comp ratio is 8:1, JE flat top piston, .039'' thick head gasket .008'' deck height, twin QFT 850 carb with pv boost ref, boost for now is 5lb but i would like to go at 7-8lb of boost, timing is set at 32 deg full in at 4000 rpm for now, I will control the timing with a map sensor probaly next week, I would like to see 34-35 in cruise no boost and 30-31 at 7-8 lb boost.
I run a B/M 250 with super chiller on a 540 with a single 1050 Dominator,I have the timing locked out at 28. I have had Zero problems with this setup. Engine starts easily and idles smooth. Boost is 6-6 1/2 lbs from 4000-5400 rpm. Carb is also boost referenced at the metering block. Its a simple setup with no worries,I do run 94 octaine fuel that is available here in Canada. I am useing Bosch HR 9 spark plugs gapped at .035. Plugs are spot on for heat range. Not an extended tip. Compression ratio of 8.1 with steel heads.
V.I. Outlaw is offline
