Whats a better ride
Old 05-19-2013 | 05:17 PM
Default Whats a better ride
Currently looking at two boats. 28 cigarette and a 27 fountain. Which would have a better ride in the chop of lake st clair and the detroit river?
Katanna is offline
Old 05-19-2013 | 05:24 PM
I would think the Cigarette, as the cig is a larger / longer running surface than the Fountian....you loose "weted surface" length because of the beak and integrated swim platform
just my opinion
welfare racing is offline
Old 05-19-2013 | 06:12 PM
just my opinion
i agree . though the 27 fountain is an awesome boat too ....
state1310 is offline
Old 05-19-2013 | 06:33 PM
I would say the Cigarette would do better in the rough but the Fountain would be faster and more efficient with the same power.
Racerngr1 is offline
Old 05-19-2013 | 06:45 PM
Tim G.'s Avatar
Performance Boat Center
A friend of mine had a 27 Fountain years ago... I had a twin engine 28 Pantera at the time... The Pantera would outrun the Fountain easily, especially if there was anything more than a 1' bump.. Every time we went out he had a lot of broken parts to fix... The boat just fell apart when he ran it hard enough to try to keep up.
the old Cig may not run as fast, but it will likely ride better... That Fountain is awful small in the water... There are a lot of other boats to choose from in my opinion.
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 05-19-2013 | 07:29 PM
Agree that 27 is small on the water and cockpit room. Probably a lot more up to date though
WorkCheck is offline
Old 05-19-2013 | 09:05 PM
Nightlife1970's Avatar
I would call a 27 Foutain the same as a Baja 24OL in size. Had one sitting next to my 280 one time, there was a huge difference in size.
Nightlife1970 is offline
Old 05-19-2013 | 09:14 PM
The 27 Fountain was really never intended to be a offshore big water boat. They offered 38's, 42's, and 47's for that. The 28 Cig, was more offshore oriented, and will provide a better ride if running offshore, great lakes, ocean, etc.
A better comparison would be the 29' Fountain vs the 28 Cig. Both cool boats, but as it was said, in that size range, so much to pick from. Most importantly, if they are older boats, make sure the hull, stringers, and transom's aren't rotted. Fountain and Cigs are not exempt from this issue.
MILD THUNDER is offline
Old 05-19-2013 | 09:56 PM
Full Force's Avatar
I will say the Cig will ride better in rough, the 28 Cig is a great big water boat for it's size... not fast but solid as a rock
Full Force is offline
Old 05-19-2013 | 10:41 PM
The cig will ride better in rough stuff for sure. The fountain is really only a 24-25 foot boat with a single. I would assume the cig has twins.
Crossett is offline
