Head gaskets >
Head gaskets
Head gaskets
Old 05-20-2013 | 08:49 PM
Default Head gaskets
Whats the best head gasket to run on N/a BBC 10-1 cr with a 4.60 bore
vince1645 is offline
Old 05-20-2013 | 09:32 PM
Cast iron or aluminum heads? Cometic is generally the consensus choice on this board, and some of the FelPro marine gaskets are good too. Head studs would be a very good suggestion with 10:1 compression as well. Hope you are running aluminum heads with that high of a CR on marine build.
Budman II is offline
Old 05-21-2013 | 01:54 AM
Cometic or Felpro Marine. Cometics have more options for gasket thickness.
Griff is offline
Old 05-21-2013 | 09:02 AM
Ted G's Avatar
Check the Cometic specs for the required RA finish on the parts. If the heads and block are new/newly resurfaced you should be fine but if the finish on both parts is not correct the Cometics will fail. Felpros are more forgiving.
www.cbpba.com
Ted G is offline
Old 05-23-2013 | 08:22 PM
Yes they are aluminum heads and the surface is new on both sides.
What size bore on the gasket?
Old 05-23-2013 | 08:56 PM
GPM
GPM is offline
Old 05-23-2013 | 09:32 PM
Old 05-23-2013 | 10:12 PM
GPM
You might want to check out the Felpro 1077 MLS
GPM is offline
