IMCO hydraulic steering fluid? >
Old 05-23-2013 | 09:41 PM
Default IMCO hydraulic steering fluid?
My 91 scarab has the original IMCO external hydraulic steering setup and I am not sure what fluid I should be using in it. I saw an old thread where ATF was recommended, and what is in the pump now looks to be ATF. I have not bought ATF in a few years and was surprised to find about 5 different kinds of automatic transmission fluid. Is Type F what I want to use if in fact ATF is what I should be using?
dandercam1 is offline
Old 05-24-2013 | 07:07 AM
Dave M's Avatar
Veteran: Navy
I use plain old PS fluid.
Dave M is offline
Old 05-24-2013 | 05:24 PM
wayne272's Avatar
I called imco the other day about the fluid since I had pulled my motors out over the winter and needed to refill the system. I still had a little atf in the system and they told me to get out as much atf as possible and refill with a quality ps fluid. The atf eats up the seals in the pump over time.
wayne272 is offline
Old 05-26-2013 | 06:24 PM
Imco told me standard power steering fluid as well.
cp5899 is offline
Old 05-27-2013 | 08:20 AM
have been told only to use the high performance non-foaming P/S fluid from GM
ezstriper is offline
