velvet drive trans >
velvet drive trans
velvet drive trans
Old 05-26-2013 | 08:32 PM
Default velvet drive trans
So today I got to take my cig out with new power and new konrad drives . The power is high 700 well it was all good till the trans started slipping and went out . So my question is what do i do rebuild them ? Change to a better style ? Upgrade clutch disc ? Give me advise on what to do . And is there a left and right ?
kennyd is offline
Old 05-26-2013 | 09:05 PM
Hi Kennyd , first off there is no right or left . The counter rotation is in the drive . The stock BW tranny has 7 forward clutches and 3 reverse . Given your horse power I would suggest that you upgrade to 9 forward clutches . This can be done without serious modification of your existing tranny's .
RG.
Rick G is offline
Old 05-27-2013 | 07:50 AM
i read that the velvet drive has selectable rotation on the front of the trans. that you match to your engines rotation by unscewing the pump and tuning it to the desired position.
jaxon is offline
Old 05-27-2013 | 04:06 PM
Jaxon in this particular application you don't want to do that as the engines both rotate in the same direction . The drives rotate in different directions . If you don't put the pumps back together exactly as you disassembled them you will not have any oil pressure and will hurt the tranny.
RG.
Rick G is offline
Old 05-27-2013 | 06:23 PM
O.C.Barry's Avatar
I have a pair of C72 plug in transmissions that have been upgraded by my engine builder (Steve Conniff builds engines, transmissions, and drives and has his own 100+ MPH non step Fountain Executioner) These have 30 very gentle hours on them. $600 each plus shipping.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
O.C.Barry is offline
Old 05-28-2013 | 08:21 PM
VP of the tickfaw200
Hubber marine upgraded mine to 9 forward clutches and tapped the case to add a line to lube the rear of the trans.
caseyh is offline
Old 05-28-2013 | 08:29 PM
Let me ask another question . What fluid should I use in a velvet drive ? Atf ?
kennyd is offline
Old 05-28-2013 | 09:21 PM
HUSTLEthis's Avatar
Type F
HUSTLEthis is offline
Old 05-29-2013 | 08:41 AM
CIG3's Avatar
Type F only
CIG3 is offline
Old 05-29-2013 | 08:44 AM
well thats probally what smoked mine , i used dextron 3 . i know dextron and type f DONT mix .
kennyd is offline
