OK...i got shocked by my throttles today.....HELP!! >
Old 05-30-2013 | 06:27 PM
Default OK...i got shocked by my throttles today.....HELP!!
So I put the outlaw in the water for the first time today and as I am rolling down river I reach down and put my hand back on the throttles.....ZAP!!!...I get the crap shocked out of me....so I figure maybe this is just a static charge....wait a couple minutes and do it again..wham!! Does it again... OK...what the hell is this???? Had to go to work so I put her back on the trailer and I'm gonna look at it in the morning...it doesn't do it when the engines are off....I'm gonna pull the throttle/shifter out and take a look, but has anyone heard of this before? Any advice to help me troubleshoot this would be appreciated!!!
rumrunner29 is offline
Old 05-30-2013 | 06:39 PM
Unless you have trim in the throttle the only electrics will be the neutral safety switch. It helps to have an extra set of hands to hold it all together as you take it apart and put it back together. If they are the standard K. setup there are springs and balls in there so be ready for flying pieces.
phragle is offline
Old 05-30-2013 | 06:46 PM
I do have trim on the throttles...but it doesn't shock me unless the motors are running...
Old 05-30-2013 | 06:52 PM
someone playin joke on you? Maybe one of your plug wires hooked to your throttle cable. LOL
V.I. Outlaw is offline
Old 05-30-2013 | 07:32 PM
don't laugh....might be related......lol?
pqjack is offline
Old 05-30-2013 | 09:20 PM
check trhe plug wires and coil wire,,sounds like it may have rubbed through..but if that was the case you would have a engine miss or it would die..
FIXX is offline
Old 05-30-2013 | 10:09 PM
Ted G's Avatar
My bet is that you have a plug wire rubbed through and touching the throttle cable, should be easy to find. And if your boat is fuel injected it will run pretty good with one dead cylinder.
www.cbpba.com
Ted G is offline
Old 05-30-2013 | 10:12 PM
That's true..it runs fine, but I will check it though...its not a real bad shock...just enough to piss ya off..hopefully its just the neutral switch..
Old 05-31-2013 | 06:35 AM
This is shocking!
Sorry, had to be the first with that. :-)
Redhook98 is offline
Old 05-31-2013 | 07:30 AM
I would place my bet on this ^^^^. Spark plug wire rubbed threw to throttle cable.
92nsx is offline
