Gel still wet
Old 06-02-2013 | 05:06 PM
Default Gel still wet
Sprayed some gel and its still wet in some places , It's my first time messing around with gel . I don't understand what I missed mixed gel with duratec 50/50 added 2 % hardener temp was in the 80 s , any ideas would be great
Matjluk is offline
Old 06-02-2013 | 06:37 PM
If the gel and Duretec were fresh, and the temperature was in the eighties, and the MEKP was added properly by volume, then it would seem that there was insufficient mixing. MEKP does not automatically disperse in gel, and needs to be stirred more than you would like. Hope that this helps.
ren3 is offline
Old 06-03-2013 | 07:06 PM
Well I'm out of town for the week ,but after 2 days a portion of gel is still not dry I was re gelling the silent thunder platform on a formula , just wondering what the best thing to do would be if its not dry by the time I return in 5 days is ,any ideas before i drop kick it and start the process over !!
Matjluk is offline
Old 06-03-2013 | 07:18 PM
Did you put in wax paraffin on the last coat. Mix for two minutes.
LOTOWONTOPGUN is offline
Old 06-03-2013 | 07:32 PM
Wax paraffin ? After 2 coats it looked awesome was going to sand then shoot the third coat , any way that was when it was wet now some is still wet and the other half that's dry looks like it has a layer of shellac on it lol
I got plenty of gel,hardener and duratec left what would be the best advice if I were to reshoot this weekend I gotta get this boat in the water ASAP
Matjluk is offline
Old 06-03-2013 | 08:42 PM
Fiberglass Supply - Polyester Resins for Surfboards, Tooling, Boats, and more.
Old 06-03-2013 | 09:02 PM
Look for the Surface Agent.
You could wash it all off with acetone and start over. Keep trying and what part of the boat are you spraying.
You must mix the gel and hardner for two minutes no BS.
Mix in the surface agent for the last coat of spray.
Look out for over spray on the rest of the boat- cover it.
Old 06-03-2013 | 10:17 PM
You also need to put PVA on it for it to cure properly
bobsbillets is offline
Old 06-04-2013 | 12:40 AM
c_deezy's Avatar
If you are using duratec you don't need pva or wax.
But it does sound like you didn't get a full mix with the mekp. If it still hasn't cured wipe it off with acetone soaked rags, let it dry, sand and try it again. Make sure you are scraping the sides and bottom while you are mixing.
c_deezy is offline
Old 06-04-2013 | 12:48 AM
Q: If I use this product, do I still need styrene wax to get a complete cure in top coating situations?
A: No. For added insurance, you could spray PVA over the gel coat to provide another way to seal out the air. Only add styrene wax if performing boat hull repairs below the waterline.
Duratec Clear Hi-Gloss Gel Coat Additive | Fibre Glast
