I need a Lee intercooler or just the core ! BAD !
The one I had that was plugged was finaly cleaned out and flowing good as new . The one I thought was good , turns out leaks like crazy !
Does anyone have one they want to sell ? Or where can I get the best deal on one ? THanks ,JOE
Oh ya make sure you put the restrictors in the intercoolers so that water does not flow through them untill you hit the higher RPM's. Biggus just racked his head against the wall untill Nickerson told him the problem. Running perfect ever since.
Jon
Jon
Put your best foot forward!
I am not 100% sure were they go. As I understand just from talking to him they attached to the front of the intercooler. In line with the line that feeds the intercooler. Once the preasure hits a certain point the valve opens up and lets the cooler do its thing. I guess that they problem was that when the cooler was seeing water go through it at IDLE it would turn the fuel into Droplets that puddle in the bottom of the intake and run to the rear cylinders and foul your plugs.
JOn
JOn
Jon, What I thought about doing was adding another set of water pickups to the transom to force feed just the coolers . That way you only get flow at speed ,not when sitting .
I have seen a few this way .
Can Anybody help me find a cooler ??
That should work ok. I am not sure if Biggus has a large water pump or not that feeds his. So far his has been real good since he fixed that problem.
Jon
Jon
