Removing I/O's from boat.
I have twin inboard outboards in my magnum 27 sedan. I'm restoring the boat and was wondering how to remove the twin Holman Moody's and the Volvo Penta drives. I know how to remove the all the accessories going to the engine and the bolts. My problem is how do you lift the motors out of the boat without taking it to someone and having to pay to get them removed. I also don't have a forklift to lift them. Is there any type of mechanism that I can make to remove them. Thanks for any replies.
I think I am going to build a a-frame and use a Cable winch puller to lift it. It's the easiest for me because it's going to be in a warehouse my dad built and it's 12ft high so it would be easier to build a a-frame in the warehouse. Can anyone tell me ways to make a wood a-frame to pull the engines. Thanks for any replies.
We built one years ago out of 4x4s and did it with a chain hoist in a gravel storage lot, way back when my buddy and I lived in townhouses with no place to work on the boats. I don't have any pictures, but it had single vertical 4x4s as posts, and double 4x4s across the top bolted together. We pulled his fully dressed 502 and reinstalled a couple times with it.
But, a tow truck with a boom on it would be the easiest and quickest way to go.
many years ago i used to have a guy with a tow truck lift them out for me like sydwayz said,he would lift the engine out and be gone in less than 30 minutes.in my opinion this is safer than a wooden home made a frame.
In the past, I've removed and replaced the engines with a tow truck with the boom extended out ,, safe and easy.
I would bet that you could also rent a Metal A frame from some of those tool rental places like Cresco
Thank you
Jim
Thank you
Jim
