454 / 7.4L MPI Mercruiser, 109 orig hours, complete drop in, freshwater $5000 >
Old 06-05-2013 | 12:13 PM
fantastixvoyage's Avatar
Default 454 / 7.4L MPI Mercruiser, 109 orig hours, complete drop in, freshwater $5000
Stock 7.4efi from a 22' sportboat. Freshwater its whole life, 109 orignal hours, serpentine belt setup, sharp motor. Full drop-in.
Prefer local pickup but could ship at buyers expense. Zip 48150
$5000
Attached Thumbnails 454 / 7.4L MPI Mercruiser, 109 orig hours, complete drop in, freshwater 00-454efi.jpg
fantastixvoyage is offline
Old 06-05-2013 | 12:59 PM
Good Seller!
Ive seen this motor and it looks brand new.
cjmatt is offline
Old 06-05-2013 | 10:12 PM
330hp?
cig20 is offline
Old 06-05-2013 | 11:15 PM
Yep 330 smooth starting, smooth running horses
Old 06-06-2013 | 08:01 AM
what year and will it bolt up to a alpha
cig20 is offline
Old 06-06-2013 | 09:49 AM
Knot 4 Me's Avatar
310 HP. Had one in a '99 266 Crownline. Made them from '98 - '00 or '01 when the 6.2 MPI replaced it. They make a bunch of torque so I would be careful with one if front of an Alpha.
Knot 4 Me is offline
Old 06-06-2013 | 10:30 AM
Not sure, looking up the VIN mercury calls out '98-'00 and by sequence it seems like a later one. As for use with an alpha I haven't worked with them much but i wouldnt think it would be a problem.
Old 06-06-2013 | 10:32 AM
Guess we were typing at the same time. Yes, could be 310hp, I just know its not the high output mag motors which are around 365hp I think
Old 06-06-2013 | 11:13 AM
Its the "310''HP version. Much better than the old 330. It has vortec heads, 9:1 and a roller camshaft. 330's had peanut port heads, 7.9:1 compression, and flat tappet. Very smooth engines and very reliable.
MILD THUNDER is offline
Old 08-30-2013 | 04:35 PM
Is it still avialible
Dwight is offline
