1991 eliminator daytona    fells like i am draging something at low speeds >
Old 06-10-2013 | 01:26 AM
Default 1991 eliminator daytona fells like i am draging something at low speeds
1991 25ft eliminator Daytona merlin 565 8/71 B &M blower 6lbs boost 1000hp bravo xr drive with imco 2" shorty with 2" spacer
prop shaft is 2" under bottom of boat with spacer 32p lab bravo prop this is my first cat and this boat had 2 outboards on it when I got it and I had the conversion done the boat comes out the the hole a little slow motor sounds like it works hard tell about 55mph then motor sounds like it frees up and boat takes off and pulls haed also at between 45 and 55 mhp
when hitting boat wakes it feels like it really wants to speed up as it paks air
klaus0404 is offline
Old 06-10-2013 | 02:57 PM
GPM
Is it a 25 or a 24 ?
GPM is offline
Old 06-10-2013 | 04:18 PM
Honestly I like that size Daytona with OB's better than an I/O. But it sounds like your x dimension is off. Try going to a 1 inch spacer.
Wannabe
wannabe is offline
Old 06-10-2013 | 09:54 PM
johnnyboatman's Avatar
Why did you put a shorty then a spacer ? How did it run with the shorty only.
johnnyboatman is offline
Old 06-11-2013 | 07:27 AM
Was the prop labbed just for that boat? I would think it should pack air around 60. When you take off out of the hole, try turning slightly to the left or right...I have been told this helps the smaller daytonas plane.
JRider is offline
Old 06-12-2013 | 04:01 PM
Sorry. Its a 24ft. Bought the shorty and it had the 2" spacer when I got it.
Old 06-12-2013 | 04:05 PM
And about 58mph is when it comes out of the water and takes off I have a spray behind the boat I think water is hitting my imco steering rams the spray
also goes away about 58 mph
