Who's running fuel press regulators with carbs? >
Old 06-11-2013 | 05:25 PM
Default Who's running fuel press regulators with carbs?
If you're using a fuel press regulator for your carb, what brand/model?
I'm leaning towards Aeromotive at the moment. Need input from you guys.
zz28zz is offline
Old 06-11-2013 | 10:03 PM
Mallory 250 pump, filter and regulator. It all works great. I'm sure Aeromotive would be fine. Im no expert, that's just what I have.
My Addiction is offline
Old 06-11-2013 | 10:12 PM
Rookie's Avatar
Mallory 140 fuel pumps and Mallory 4140 regulators. I dead head mine now, but plan on retuning fuel back to the inlet of the pump this year.
I'm also sure the Aeromotive will be more than adequate.
Rookie is offline
Old 06-11-2013 | 10:26 PM
Default Aeromotive regulator and pump on mine.
Same here, but all Aeromotive with a fuel return line to the fuel fill hose. 14 psi pump.
[ATTACH=CONFIG]502468[/ATTACH][ATTACH=CONFIG]502469[/ATTACH]
Attached Thumbnails Who's running fuel press regulators with carbs?-2013-06-04-19.31.13.jpg   Who's running fuel press regulators with carbs?-2013-06-04-19.31.05.jpg
toyo321 is offline
