Does the oil pump require a gasket? >
Old 06-11-2013 | 05:25 PM
Default Does the oil pump require a gasket?
I ordered a melling pump for my 454
Mag and it did not come with a gasket. Did some reading and though they sell gaskets for them I read they should not be used. So I checked the witness marks on the block and oem pump and it does not look like a gasket was installed. So gasket or no gasket? Thanks!!!
Port Monster is offline
Old 06-11-2013 | 05:33 PM
Vinny P's Avatar
I hate the winter!!
No gasket is used, but there should be an "O" ring between the pump and the rear main cap.
Vinny P is offline
Old 06-11-2013 | 05:45 PM
I did a short block rebuild at the local machine shop and the URL you have me is not coming up. So I assume that the o-ring is installed and the mating surface between the pump and motor does not need an o-ring?
Old 06-11-2013 | 05:56 PM
Vinny P's Avatar
I hate the winter!!
http://www.mercruiserparts.com/Show_...sp?dnbr=804807 99&ivar=images/COMMON/20119.png&inbr=4854&bnbr=170&bdesc=Cylinder+Block+ and+Camshaft
Try this link...
Vinny P is offline
Old 06-11-2013 | 06:18 PM
I feel like a technical retard - looked at the 454 Gen IV diagrams and don't see a o- ring!
Old 06-11-2013 | 07:20 PM
So I can't even find a gasket number - just some odds and ends gaskets available on the internet. I looked and there is not any groove for an o-ring so that does not seem like it fits my application. Anyone have any additional advice on this??
Old 06-11-2013 | 07:39 PM
no gasget or o ring is used on any gen of bbc for mounting the oil pump,NONE
mike tkach is offline
Old 06-11-2013 | 07:42 PM
mike is correct NO GASKET +++NO ORING bolt it on and your done
smokin' gun is offline
Old 06-11-2013 | 07:46 PM
Thanks gentlemen!
