Transom Patch TRS to Bravo
Im converting a 1990 Cig TG from TRS to Bravo, I need to patch the transom to redrill new holes.
Whats the easiest way to Patch transom?
Are there any old Post on Patching Transom?
Frank
Frank
put a new transom in, there is no real easy way. The Bravo hole is smaller then the TRS and on a boat that size for safety sake you really should just do the whole thing.
08 OPA High Points Champion
Agree with Dave and there is no easy way even if you decide to "patch " the hole if you plan on doing it right. We just finished a little while ago a TRS/Konrad to 6a transom job. To put it lightly it is a ton of work. Keep in mind the 6a drive cutout is slightly large than the TRS.
