Skeg.... Fix it or leave it alone? >
Old 06-13-2013 | 11:59 AM
Default Skeg.... Fix it or leave it alone?
What would you guys do with this other than replace it?
Leave it alone or square it off?
Bravo one on a 21" boat with low speeds.
illMATTic is offline
Old 06-13-2013 | 12:07 PM
Big Time's Avatar
On a smaller boat at lower speeds, I don't see that as having a significant impact on performance/handling, so from that point of view it doesn't seem like it's worth fixing, especially if you think there is a chance for it to happen again. I would leave it alone...
Big Time is offline
Old 06-13-2013 | 12:15 PM
If that was my boat i would not worry about that. I have seen people run boats with no skeg.
30ftpanther is offline
Old 06-13-2013 | 12:22 PM
find a local welder that can weld aluminum and get it fixed shouldn't cost more than $50. That's exactly like mine looked like before I welded a piece in and smoothed it up. It was more of an eye sore than anything
tnc110 is offline
Old 06-13-2013 | 12:23 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
File it off at a smooth angle and paint it, purely for looks only. That won't hurt a thing.
Sydwayz is offline
Old 06-13-2013 | 01:01 PM
Ya I hate how it looks. Have to explain it to some ******* at the launch everytime I go out. It was like this what I bought it.
Thanks guys.
Old 06-13-2013 | 04:50 PM
Buy a skeg guard on-line---under 100 bucks--drill 2 holes--tap it on--DONE !!!! Looks good and it will not need painting !!!
1stoutlaw is offline
Old 06-13-2013 | 05:27 PM
do not use a skeg guard they screw up the water flow to the prop
pstorti is offline
Old 06-13-2013 | 06:23 PM
I would just file it down to a straight line and paint it. It happened to me and that's what I did. Looks great afterwards. I believe that skeg is to help with steering and to protect the prop a little. You still have enough skeg to do its job.
Greggcellent is offline
Old 06-14-2013 | 07:27 AM
badmonkey's Avatar
Is it really an issue with Skeg gaurds. Was considering getting one for mine.
badmonkey is offline
