Morse control and twin Bravo installation
Issue is with old style binnacle mount Morse dual shift/throttle control using counter rotating Bravo Drives. Seems to be an issue setting up port drive for reverse rotation using the Old Original Morse Binnacle controller that was set up for right hand Alpha...how do I make it work?
Cable needs to hook to the opposite side of the pivot, may need to make a bracket so it does the opposite of what it's doing now when the lever is pushed forward. All bravos can run either direction one cable pushes and one pulls
Turns out that the problem is that the old style Morse doesn't have enough throw in the lever to work the Bravo in the counter clockwise mode. so until I upgrade the control I have to stay with both Bravo drives turning right hand or clockwise. New control in the plans now.
