2006 42 legacy electrical issues >
Old 06-13-2013 | 10:33 PM
Default 2006 42 legacy electrical issues
Hi folks, I have a 2006 42 legacy. When I turn on the key no clicks can be heard and the master control panel is dead. I either have dead batts or a voltage regulator out I think. I cannot open engine hatch and because control panel is dead cannot use shore power to charge batts.. Is there another way to get to the batts or something to get the hatch open? Any help would be much appreciated. Thanks. Jim.
32 is offline
Old 06-15-2013 | 08:21 PM
You might have one of the automatic battery switches that went out if nothing happens when you turn the key on. Open up your side pouches and there is another zipper inside that you open. Once in there you can switch them to the manual mode and the dash should be live at that point.
Enough 4 Play is offline
Old 06-18-2013 | 08:45 AM
WildThing47's Avatar
There are battery posts under the rear seats. Get a jumper pack and you can open the hatch
WildThing47 is offline
