Bilge paint question
Iam thinking of using the sherwin two part Polyurethane
paint for the bilge,,how long will it take to dry before you can stand and work in bilge after the two coats are applied???
I just got done priming mine with SW paint yesterday, it's a 2 part primer, it was hard as nails this morning, I'm putting 2 coats of the the primer, and than 2 coats of the SW poly....I'll let you know how the top coats work out, but to answer your question I would think you should be good to stand in it the next day....
I striped and sanded my bilge, tried to level and straighten it out, the older Cig bilges were pretty rough...so I primed first with SW B58w610 part A and B58v600 part B, mixed the two together 1to1, two coats, and then I used B65w311part S paint, B60v30 hardener mixed 4to1, 2 coats....I think I paid $250 for everything, gallon of primer, and gallon hardener for primer, gallon of paint and a quart of hardener for the paint, its enough to do 4 boats...
