presssure testing exhaust ? >
Old 06-22-2013 | 11:05 AM
bck's Avatar
bck
Charter Member#568
Default presssure testing exhaust ?
Is there a certain pressure that should be used when using air or water to test for leaks? I'm hoping to use water as I already have the fittings to hook the exhaust up to a garden hose. Just worried about putting too much pressure in them. Thanks
Straight bottoms and flat decks
bck is offline
Old 06-25-2013 | 01:27 PM
If you use a garden hose, it wont be too much pressure. If that were to "cause" a leak, they were going to fail soon anyway.... IMHO
mallatt442 is offline
Old 06-25-2013 | 01:35 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I concur . Turn on the hose and let em set for awhile . Welded stainless steel should be able to take much more pressure than is in your home's waterline .
the deep is offline
Old 06-25-2013 | 02:08 PM
A garden hose is a pretty severe test. You only need around 20 psi.
kvogt is offline
Old 06-25-2013 | 07:03 PM
bck's Avatar
bck
Charter Member#568
I figured it should survive a garden hose but didn't want to tempt fate by putting in so much more pressure than it would see during use.
bck is offline
