what should the sea water pump pressure sensor read on a 496 >
Old 06-25-2013 | 06:09 AM
Default what should the sea water pump pressure sensor read on a 496
I have a conflicting reading with my sea water pump pessure sensor readings .I have twin 2004 496 (pcm555) one eng says 3psi and the other says 42 psi at idle. which is correct?
larry da outlaw is offline
Old 06-25-2013 | 06:19 AM
3lbs is correct the one that says 42 is bad and needs to be changed
ballz2thewall is offline
Old 06-25-2013 | 09:35 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Agree with above post. I just replaced one due to exact same issue. The high one is bad.
Sydwayz is offline
Old 06-26-2013 | 05:51 AM
thanks I just replaced the sensor...all is well
