Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
removing resin drops.....im a slob! >
Old 06-25-2013 | 10:12 AM
Default removing resin drops.....im a slob!
Did a cpl repairs on a boat & now I'm noticing some resin thats on the non skid platform. It's ground in pretty good & dirty.
Any magic tricks to getting these off?
scarab63 is offline
Old 06-25-2013 | 11:06 AM
Take a little sharp chisel and tap out, most of the time they will pop right up without damaging anything
Ktrain is offline
Old 06-25-2013 | 11:29 AM
It's not raised anymore, but rather ground in with dirt / $hit mixed in
scarab63 is offline
Old 06-25-2013 | 03:30 PM
Ur screwed.
Ktrain is offline
Old 06-25-2013 | 09:30 PM
Lol
I've tried steam powerwash. Tuff stuff, bleach, raping it with the side edge of the buffer.
I know someone has some secret potion!!!
scarab63 is offline
Old 06-26-2013 | 12:44 AM
Default fixx
super X non chlornated brake cleaner and a fine scrub brush,,get it on quick scrub quick and wipe it off quick..it works! acitone will also work but is a little stronger..
FIXX is offline
Old 07-01-2013 | 02:24 PM
Acetone was a no go....
Gasoline maybe. It looks like a dozen bird shats on the platform! Nfg
scarab63 is offline
Old 07-01-2013 | 06:30 PM
It's not going to come up, unless u chip it.... At least I have found nothing that works
Ktrain is offline
Old 07-01-2013 | 06:45 PM
Scrape it with a razor blade. Keep it at a 90° angle or you will **** it up. Then hit it with 2000# and rub it. Megires stones work well too...
POWERPLAY J is offline
