damn porposing!!!!!!????????
I have a baja 21 foot that runs 74 mph so far. I have tried several props.. B1s run to much tramsom lift but accell. great and handle great but runs only 68 mph. The trophy 4 blade runs 69.5 but doesnt accell as good as the b1. The lazer runs 74 but if i trim to max speed it porposes a lot which seems like its holding me back , if i trim it down its too wet and slows down. Im soooo close to cracking 75 i can smell it. Do you think a mirage will work?
thanks sj
thanks sj
Oh and by the way, Look at the two outermost chines on that boat and I'll bet you see some hook in the last eight inches or so. This is out of the water at speed, but Baja says it is still subjected to "soft water". I think they mean water that is coming off of other parts of the hull, i.e., non solid spray..
Arneson rocker plates! They’re $$$ if you think of them in terms of just trim tabs. But you have to look at the added length you’ll get. And at 70mph+ in a 21’ boat you could use it. Arneson Rocker Plates
