Dyna Mat in a boat?
Old 06-29-2013 | 08:45 AM
Default Dyna Mat in a boat?
As I plan my interior finish re-do I was wondering if anyone has used Dyna Mat in a boat? http://www.dynamat.com/
I have used it in a few Muscle Car restorations and love it. I wonder if anyone here has first hand experience using it in a boat?
Thanks in advance.
sprink58 is offline
Old 06-29-2013 | 09:24 AM
I have not but I have seen a motor compartment done in it. I would do it just because the resonant point s of glass VS steel would be different and added weight. Accoustic foam would be a better choice in my opinion...egg carton foam...but only in dry areas of the boat!
JRider is offline
Old 07-01-2013 | 11:43 AM
I have used it on the hidden inside areas of my fiberglass cockpit liner and around/behind my stereo speakers. It seemed to help some, especially on the big flat areas of the cockpit liner. It seemed to deaden that hollow resonance sound. Even hitting the palm of your hand on the surface you could tell a before and after difference. I’m sure every boat will be different but I don’t see any downside to it other than weight and cost.
johnny b good is offline
Old 07-01-2013 | 12:06 PM
I use window membrane from Home Depot when I do stereo installs. Does the same thing at a fraction of the cost.
4bus is offline
Old 07-01-2013 | 01:51 PM
i used soundproofing on some tackle lockers mounted on my console that were vibrating like crazy next to the subs, it is similar to dynamat and it solved the problem. Where do you want to use it?
pstorti is offline
