Best hub and prop for alpha? >
Old 06-29-2013 | 09:16 AM
Default Best hub and prop for alpha?
Hi everyone, I am in need of a new prop for my boat and see about three different main companies, Solas, Michigan Wheel, and turning point. What does anyone have opinions on which is the best prop? Especially for the hub, I know all these companies have a slightly different design. Also if theirs any other companies flee free to tel me about them. I would be getting an aluminum prop. Thanks
jbizub5192 is offline
Old 06-29-2013 | 01:00 PM
I run a mirage plus on my alpha. A bit slow out of the hole though. I hear small blocks love the Laser 2.
79formula is offline
Old 06-29-2013 | 01:46 PM
It depends on you boat and engine combination
obrien is offline
Old 06-29-2013 | 06:45 PM
yah! what boat you have really matters.
FIXX is offline
Old 06-30-2013 | 08:52 AM
Sorry forgot to mention that. Its a 19ft bowrider with a 4.3lx. Thanks
Old 07-01-2013 | 10:11 AM
The boat also weights about 1700lbs if that helps. Thanks
Old 07-01-2013 | 08:56 PM
try a turbo 2+2,,they work gr8 for bow riders and you will use half the fuel..drop down 1 pitch's so if your prop is a 19 buy a 18 pitch one,,you can also trim the piss out of it..also good for water sports..
FIXX is offline
Old 07-01-2013 | 10:09 PM
Thank you, It looks like a nice prop but I want to stick with aluminum (forgot to mention that).
Old 07-01-2013 | 10:36 PM
Any specific reason you want to stay aluminum? You might see some significan gains with a high quality stainless prop like the one mentioned above. Fuel savings alone might pay for it over a season.
RT930turbo is offline
Old 07-01-2013 | 10:46 PM
If he's running in any lakes like buckeye minus the 8 inches of mud aluminum is probably to save his drive.
But I agree with Artie if you run in a nice deep lake go stainless, aluminum tends to warp at high rpms.
s022mag is offline
