Who's familiar with 600c tabs? >
Old 07-01-2013 | 09:37 AM
bck's Avatar
bck
Charter Member#568
Default Who's familiar with 600c tabs?
One cylinder is moving much slower than the other on one of the tabs. I took the tab off to refinish it and ran the cylinders up and down and noticed one lags behind the other by several seconds. The cylinders on the other tab both move at the same speed. there don't seem to be any leaks. How do I diagnose and fix whatever is wrong?
Straight bottoms and flat decks
bck is offline
Old 07-01-2013 | 03:53 PM
Mbam's Avatar
Offshoreonly Advertiser
Brian, it might not be a problem. Unless they are connected together by the tab the one with the least friction will move first/fastest.
Mbam is offline
Old 07-01-2013 | 06:34 PM
bck's Avatar
bck
Charter Member#568
Ok. Hopefully that's the case. The twin tubes on the other side go in and out at the same speed so I thought there might be a problem with this one. I was worried something was wrong with that canister thing in between the tubes. I'm sure that is almost made of unobtainium by now.
bck is offline
