Installing a kill switch?
Old 07-01-2013 | 10:50 PM
Default Installing a kill switch?
Bought 2 universal kill switches for the poker run I'm attending in 2 weeks, not sure it's necessary but won't hurt to have them. How hard is it to install as far as the wiring goes. The back of the plug has four pins, 2 ignition and 2 magneto. Haven't looked at the back of my ignition switches yet but what should I expect to see. And what needs to go where. The instructions are terrible.
s022mag is offline
Old 07-01-2013 | 10:52 PM
I have the single switch that kills both engines. Bought at cp. it has four wires on back. 1 set for each engine. Interrupts ignition hot. Very simple
Crude Intentions is offline
Old 07-01-2013 | 10:58 PM
So I could get by with just installing one switch?
s022mag is offline
Old 07-01-2013 | 11:02 PM
I would think the wiring on a 88 311 would be similar to an 86 - 272. On mine, I have a hot lead that powers the fuse rail. Each engine ignition has a separate fuse on that rail. A wire goes from each fuse to the ignition key switch. The ignition key switch should have two wires then leaving it. One will go to the starter on the engine, so it will go directly to a wire harness plug under the dash. The other is the ignition lead and will also provide power to your gauges. You need to find the wire that goes to the gauges/ignition. You want to cut that wire after the switch and before it connects to anything else. Install the lanyard switch where you cut that wire.
When the lanyard is open, it will remove power from the dash panel and the engine ignition. The motor will still crank over if you turn the key, but without ignition power it will not start. You will not use the Magneto contacts.
Brian
befu is offline
Old 07-01-2013 | 11:04 PM
No you can not. If you run them both off of one switch, they will have a common ignition source. Then once they are running, the key will no longer turn one motor off. You would have to shut down both motors to kill the ignition power source.
the single switch that kills both motors has two separate switches built into it, called a single throw - double pole switch.
befu is offline
Old 07-02-2013 | 08:07 AM
Ok. I didn't think I could do that either after I thought about it. Gonna try to do it tonight.
s022mag is offline
Old 07-02-2013 | 09:27 AM
http://www.cpperformance.com/p-13200...op-switch.aspx
Here's the one I was talking about
Old 07-02-2013 | 10:54 AM
I installed that very switch! Never have made it work though. I'm sure I wired it wrong. Sure looks purty, but doesn't do a damn thing! I keep meaning to get back and switch the wires around but it is a beotch to get to the back of the console.
CrownHawg is offline
Old 07-02-2013 | 01:16 PM
Just interrupts ignition hot. If no power to ignition engines stop as that power feeds coil.
Old 07-02-2013 | 03:59 PM
Rookie's Avatar
You can run just one switch. You need to put the lanyard on the hot wire that powers the ignition switches before the switches. Then the keys will cut the power to individual engines but the lanyard cuts the power to both ignition switches. That's how I have them wired in.
Rookie is offline
